New 3GX Versions coming soon
  • New 3GX Versions coming soon
    Looks like Align have a couple of new units on their way soon.
    Blade mCPX - now Version 2
    Only useful for up to a 450 imo, a bit of a waste!
    Liam
    Lotsa quads nd fpv stuff on a:
    Futaba T8J
      I wonder what price point they will come in at as they are promoted as suitable for 250/450 sizes for one and 250/500 sizes for the other. Could be intro FBL units and Align may bring out a unit that is suitable for 50/90+ sizes later
        Liam
        Yeah totally agree, a bit of a waste and whats the point ?
        I think I will stick with my Spektrum Beastx, Thank you...
        Bradley
        Align Trex 550e Skookum SK-720 FBL
        Align Trex 450 Pro BeastX FBL
        E-Flite Blade MCP X v2
        Spektrum DX8
          am i readin rite no reciver needed.
          500epro c/c bx dfc 7c 500 dominator g.pro
            Yeah basically like spektrum BeastX. But compatible with futaba.
            Futaba T8J
              Judging by the socket with "Ant" near it and the compatibility with *both* spektrum and futaba won't it need a satellite "Ant"enna?
                I think that you could add a sat to make it have larger range so possibly for use on 500+ sizes, but for futaba to make it larger you'd need a rx.
                Liam
                Futaba T8J
                  At least the cases are not chromed, so hopefully no static issues to reset the darn thing.
                  If they are cheap enough they might be a good though limited addition to the range?
                  D
                    ...ut for futaba to make it larger you'd need a rx.
                    Need a bit more detail to be certain on that one as S-FHSS can be full range, but the limitation they mention may come from only having one Spektrum satellite.
                    Also need to consider that Only the top and bottom end of the Futaba range support S-FHSS, so this is not going to work with an 8FG for example.
                      I thought the 8FG would work with S-fhss too?
                      But considering the limitation is also on the s-fhss version. I run full range rx's on my T8J and can't see why they can't make this full range! As if it was full range it would be a winner in my book!
                      Liam
                      Futaba T8J
                        Full list here: Futaba® FHSS & S-FHSS Rx/Tx Compatibility
                        Essentially, for Futaba, it is the 6J, 8J, 14SG and 18MZ that will work with these new Align devices.
                          Ah right,
                          Guess that adds to my point, what a waste!
                          Liam
                          Futaba T8J
                            Looks like a homage to Mr and Mrs ...
