3Dx programming help.
  • 3Dx programming help.
    Sorry I mean 3Gx...
    Hi
    Can someone please give me the correct connecting up sequence for the USB dongle for getting the PC software to recognise the 3Gx unit?
    Seem to be getting a message in the software saying something like 'connection failed'.
    Are there any online instructions anywhere?
    Blade mCPX - now Version 2
    You are powering up the 3GX unit aren't you? It has to be powered up or it won't work.
      Power transmitter, power heli, connect usb to pc, start program, connect usb to 3GX
      james
      Trex 250 se, DFC, 3GX.
      Trex 500 esp, FBL, Beastx.
      Trex 600 nsp, DFC, Beastx.
      Compas 7HV, 120HV YEP, SK3 560, HV MKS, VBAR.
      Squall (less 1 wing).
      DSX9.
        OK thanks
        I'll try again when I get in later.
          let us know how you get on!
          WWW.BETSOS.CO.UK
          Betting Made Easy
            OK sorted and loaded on V1.2 firmware.
            I'll swap it over into the 700E to replace the 3G unit on there soon and try it out.
              Hi,
              Currently my 3GX device is running with v1.1 and I went through the whole set up procedure.
              The device also connects successfully to the 3GX configuration software and I can get and set configuration values.
              I've been trying to upgrade the 3GX to the latest firmware v2.0.
              The process always ends with a "Failed to write" error message a few seconds after pressing the Update button.
              When opening the Update Firmware dialogue it says "Detected the USB device".
              After pressing the Update button it says "Connection..." and shortly after it says "Loading...".
              At the same time the STATUS and GOV LED switch off (is this expected?). After a few seconds it says "Failed to write" with the progress bar still at 0%.
              I tried also upgrading to v1.2 on different MS Windows versions (Windows7,Windows XP) all with the same result.
              Does someone know what possible could be wrong?
              Thank you very much for any help,
              Andre
                3GX upgrade issue
                Hi,
                At the same time the STATUS and GOV LED switch off. After a few seconds it says "Failed to write" with the progress bar still at 0%.
                I tried also upgrading to v1.2 and on different MS Windows versions (Windows7,Windows XP) all with the same result.
                Does anyone know what possible could be wrong?
                Thank you very much for your help,
                Andre
                  Hi.
                  Originally posted by andrehkarl View Post
                  Hi,
                  Andre
                  I have the same problem.
                  Fixed the problem?
                  Thanks from Spain
                    I didn't manage to fix the problem and am still on v1.1 and flying with it (or trying).
                    Right now I'm trying to find the right combination of parameters like w or w/o gov, head speed, gyro gain, and so on to get the wagging tail steady.
                    One thing which crossed my mind is that I'm using a separate CC BEC running at the default setting of 5.1V which might drop below the minimum of what the 3GX device can handle when I'm trying to upgrade, because as I explained the 3GX device seems to switch off as soon as I start the upgrade process.
                    What is your configuration, what voltage is your internal or external BEC running on?
                    Andre
                      Hey.
                      If you are powering Align servos from your 3GX then in order for them to meet the recommened speed and torque spec's you need to set the CC BEC PRO to 6 volts output.
                      With the 3GX connection problem, most of this could probably be linked to driver issues. Did the PC register the dongle being plugged in and locate drivers to suit?
                      Another problem I have read is to make sure your Windows Media Player is up to date, as this has given problems, but off the top of my head I cannot remember the specific problem given.
                      Ian Contessa
                      Coolice Power Supplies
                        Are you using a usb extension lead, I've have read on some forum people using wrong usb lead.
                        • Flickr Through My Pictures.
                          Hi.
                          Andre
                          My 3gx device is powered by external BEC at 5v.
                          Maybe that you say is possible, for dropping voltage with all servos connected.
                          The next days I'll disconnect the servos and check.
                            Hi.
                            Mi problem exist with or without usb extension lead
                              Hi
                              Ok. I don“t know about it, I'll check for servos and receiver voltages to setting the power to 6v.
                              I have not problem with the connection, the pc connect with the 3gx, Ok. I can make changes in the configuration and write to device.
