3GX shortest review ever
  • 3GX shortest review ever
    "not too bad".
    Tried it on a 700E, I felt right at home with the heli.
    There was some elevator bounce, but higher headspeed might help. The tail was solid enough, without any parameter tweaking.
    if the weather is ok tomorrow i will post my findings on this unit
      yeah like mine too
      thanks for the mini review
      craig
        Hey.
        I would say a higher head speed will most probably increase your elevator bounce, as teh 3GX will be able to stop faster due to the increased head authority.
        To start with I would suggest increasing the elevator stop gain value, as this is used to suppress the fore/aft bobbing motion on aggressive stops.
        You can also try lowering the elevator gain and lock gain settings if the above does not help.
        Ian Contessa
        Coolice Power Supplies
          >> elevator stop gain value ...lock gain
          thanks! Changing those would require a PC interface, or did I overlook them in the manual?
            What you put it on Kel?
            Oh, I see
              Your very welcome buddy.
              Yes, unfortunately you will need the PC link and interface, do you have one?
              Ian Contessa
                no, it belongs to someone else.
                I programmed a very low headspeed, since that 700 is the owner's first heli ever. It flies well enough, there is no use to fine-tune it to perfection.
                If things go as planned, he'll increase headspeed in a couple of weeks, and then we'd have to start all over.
                I'm planning to get a 700 V2 with 3GX once it's available. I'll try the 3GX first, instead of the V-Bar I'd have used otherwise.
                  Hey.
                  Try writing my posted 550 3G settings to the models 3G system, I popped them on Pete Ayriss's 700E last weeend and they worked great and smoothed the model out nicely, removing a lot of the quirks. Again you will need the PC link and software though.
                  Ian Contessa
                    I am looking at getting at 3GX for my 500. I thought that the 3GX came with a PC link and interface - or have I got that wrong?
                    Steve
                    Logo 500SE
                    Forza 450
                      Yes it does com with a pc link interface but you with need a USB extenstion lead as the interface lead is very short.
                      Kasama Srimok (OS91HZ), Kasama Srimok (YS91SR), Srimok FIFA, Trex 700N, Trex 600N, Trex 600E, Trex 500 FBL, Xcell Tempest 91, TSK Mystar 61, Volt 700E FBL,
                        Well my first impression is.......
                        I should Have loaded the software on my field laptop as I had massive tail wag and needed to adjust the parameters so can't tell yet
                        Sent from my iPhone using crapatalk
                          did you try to change the gyro sensitivity via the radio?
                            A pretty tidy bit of flying with one here
                            ‪Korawich Thongsri ALIGN 3GX Flybarless system Test 1‬‏ - YouTube
