can someone confirm this is right on my raptor 50 in govoner function settings 8.5 ratio RPM and main rotor auto fill then adjust govoner settings in tx until i get desired head speed in main rotor can someone confirm this is correct thanx
3gx nitro raptor
Hey Buddy.Originally posted by michaelsnny View Postcan someone confirm this is right on my raptor 50 in govoner function settings 8.5 ratio RPM and main rotor auto fill then adjust govoner settings in tx until i get desired head speed in main rotor can someone confirm this is correct thanx
From my limited experience using the governor of the 3GX, what you have said sounds correct.
From memory you input the model gear ratio, the software then determines the head speeds based on the ATV value of the GEAR channel, so as you increase the gear value the head speed shown in the box increases accordingly.
.Ian Contessa
Coolice Power Supplies
Yup, once you put the correct ratio in you adjust the settings on the transmitter and the 3GX software gives you a live view of the headspeed that will equate to.
Once I'd figured it out I couldn't believe how easy it made this part of the setup.Helis: Oxy 2 FE / Oxy 2 Sport / Protos 380 / Oxy 4 Max / Gaui X3 380mm
Electronics: Spartan VX1e / Spartan VX1n / Spartan VX1p / MSH Brain2 mini / Jeti DS-14
Sims: Realflight / AccuRC / Phoenix RC (Wireless) | AccuRC (Wireless) | Realflight (Wireless)
