3GX V5 help needed
  • 3GX V5 help needed
    Hi guys, I am new to this flybarless thing but am trying to help out a club mate who is having problems with Trex 550 and his 3GX with V5 software and Spektrum DX9. We have read all the forums and etc but that has not been of any use as the main issue is the satellites and 3GX lights are not coming on when powered up, so the set up sequence cannot commence. We first tried powering it from a the Talon 90 esc in the kit and also via a separate 6V receiver battery, in case the esc was faulty but have the same problem. So the question is does the 3GX work with both Spektrum DSM2 and DSMX satellites and what else could we try?
    Barry
    Sutton Coldfield Radio Controlled Aero Club (SCRCAC for short!) Citizen 00182
    Two Blade MCP-x
    Two Blade 130x
    Red Bull 130x
    Gaui 200 V2 FBL with mini V Bar
    Trex 250SE FBL with mini V Bar and DFC head
    2 x Honeybee King 2's (now retired)
    Mini Titan E325 with Tarot DFC head and mini V Bar
    Gaui 550 CF Hurricane FBL with mini V Bar
    HK Cessna 182 Deluxe, Silver Lady and Graupner GF-15 EDF (just for relaxation)
    And a tolerant wife, what more could any man ask for?
    It does work with both DSM2/DSMX, they can't be mixed IIRC.
    It will not power up unless the servos are connected.
    Cuffley MFC www.cuffleymfc.co.uk
    Too many toys to list...
      If i remember correctly theres no lights until you bind it to the tranmitter then it lights up i made
      the same mistake
        the same mistake
        Correct, you need to put in the bind plug and bind the 3GX, once it binds it will come to life.
          Hey Buddy.
          As above, the 3GX needs to be bound to receive a signal which then allows it to power up.
          As you are using a DSMX capable set, follow the binding procedures but power up with the bind plug in and the rubber set button on the 3GX pressed, this tells the 3GX to sue DSMX mode. Then pull out the binding plug, this sets all channel user set failsafe positions rather than last position hold and go through the binding process with your transmitter.
          Ian Contessa
          Coolice Power Supplies
            Thanks for all your help guys and especially Coolice for your very comprehensive reply and hopefully we will finally be able to sort it tomorrow.
            Barry
            Two Blade MCP-x
            Two Blade 130x
            Red Bull 130x
              No worries, you're very welcome glad to help.
              Keep us posted on how you get on and any questions fire away and I'll do my best to help.
              Ian Contessa
