How on earth do I update my 3gx!!!
  • How on earth do I update my 3gx!!!
    I'm sure its something simple but how the heck do I download the 4.0 update? I downloaded the file from here;
    ALIGN 3GX UPDATE MAIN PAGE
    But all it seems to do is download a video that won't play!!
    Gary
    Futaba 14sg
    It's a .rar file... you need something like Winrar to open it
      As above but Winrar may throw up a window asking you to purchase, just click out of the pop-up & continue with setup.
      • Flickr Through My Pictures.
        Cheers for that guys, got it sorted now.
        Thanks again.
        Futaba 14sg
          I use this for unpacking of compressed files.7-Zip
          The Fleet
          Trex 450 Pro on Brain 2
          Mini Titan super Cobra ah1
          Alien 550 Quad.3DR Pixhawk
          Futaba 7C 8FGS 14SG
          Specktrum DX6i
            Ok just updated the firmware to 4.0 and I can already hear more servo twitching than before which I noticed has been mentioned a lot on here! So long is this stops the unwanted pirouette when I backflip then its all good!
            Futaba 14sg
              Did you default TX to new model, 3GX has its own memory & even with new firmware it doesn't always default only when it see changes from TX .
                The easiest way to update a 3gx is to buy a vx1
                WEA-TTI-TMFC........
                  Bearing in mind I fly with Angelos' engineer and chief test monkey its probably just a matter of time before I end up with a vortex! I must admit watching him test it out to fine tune things I was amazed at how accurately his heli stopped and how smooth it all looked!
                  Futaba 14sg
                    You're Kev Davies in disguise and I claim my £5 reward for finding you
                      That's good to hear, I was just having a bit of fun,
                      I was at Cuffley model flying club today and to see the Align-Trex team pilots fly the vx1 with v3 was AWSOME.
                      Chris Newby, Dave Fisher, John Nobbs and Ali Humphrys.
                        You could be right.... But.....
                          Hey Buddy.
                          As you were flying a 3GX before on V3, a full transmitter reset may not be required. It's more important when coming from a fly barred setup that may be using mixes and ATV adjustments to get right.
                          If anything going from V3 to V4 with the same settings will help speed up the process, as once in DIR mode to reteach the now blank 3GX it's settings to work within, all the hard work such as setting the cyclic to 8 degree's deflection is done for you. However, bear in mind any added dual rates and changes to pitch/throttle curves requiring linear control movements when in DIR mode should be removed.
                          I flew my first Vortex in a TDR a week ago, need more time with one to fully explore what can be done with it, but I made some minor tweaks to a lively setup and it flew well.
                          Ian Contessa
                          Coolice Power Supplies
                            Omg, that's why Kev didn't make it to rotors Germany, can't be in the same place as tye because there the same person!! Makes perfect sense now too lol
                            Goblin 500 SK540 jive 100lv
                            HD 500 SK540 jive 80 lv
                            Oxy 3 SK540 minijazz20
