3gx setup help
  • 3gx setup help
    Hi all
    i am setting up my trex 500, however am getting a little confused with the 3gx
    i have updated the firmware to 3.1
    the issue I'm having is setting zero pitch, I can set the pitch to be zero with the blades straight, but when I start to rotate the blades the pitch changes and no longer is zero, is this ment to happen
    i am using the align digital pitch gauge
    any other tips on setting up
    up all the servo horns are at 90 degrees
    sorry for the questions it's my first time setting up a heli
    Re: 3gx setup help
    Is the 3gx in DIR mode?
    Sounds like you have cyclic inputs in or a bent shaft. Is the heli new?
    John
    http://www.thurrockmfc.co.uk/
      Yes I followed the instructions on the laptop and held set button down while booting
      The heli is new, first time I have built and set one up however
        The tx is a Futaba 8fg btw
          Check your swash is level. any tilt will show as blade movement when you rotate the head.
          Invertix 400
          Vortex 285
          TBS Discovery Endurance
          X4 II
          Schluter Champion Longranger
          G4 E720
          G4 E720 Big AIR edition
          Goblin Urukay super slow
          Goblin 700 KSE Slow
          Goblin 700 KSE Fast
          Srimok Faifa
          Spectra G
          Synergy 766
          http://mangled-rc.com/
            Re: 3gx setup help
            Yep. As Joe said. Have you used a swash leveler? You need all the links at the right lengths.
            Also check http://www.rcheliaddict.co.uk/showthread.php?t=76163
              if your swashplate is level and you still got pitch on one blade you need to adjust the blade links to get the odd one to 0 degrees mate ...
              edit: too late
              Sev
              Thunder Tiger E700 BD3SX
              Trex 450L DFC BD3SX
              Trex 150 PRO DFC
              Blade Nano CP X
              Blade mCP X v2
              Blade 130X
              DJI Inspire 1
              DJI Phantom 2 iOSDmini
              EMAX 250 Pro V2 FPV Racer
              Futaba 18MZ
              MK Heli Club MKMAA
              Proud Owner of:
                Ok thanks i have a swash leveler, i shall use that now
                thanks for link i shall look into it now
                Also does anyone have the link length from the servo to the swashplate for a original 500 covnerted to dfc
                  When using the pitch gauge first sit it on heli frame then set zero then check blade pitch for aile then do same again for elev
                  • Flickr Through My Pictures.
                    3GX setup for newbies! They worked for me!
                    Align 3gx full setup video 1 (freddy can fly) - YouTube
                    Align 3gx full setup video 2 (freddy can fly) - YouTube
                    Align 3gx full setup video 3 (freddy can fly) - YouTube
                    Align 3gx full setup video 4 (freddy can fly) - YouTube
                      3gx setup help
                      The freddy can fly are good source of info , I set my 3gx up using these videos . I work down in pompy (hilsea) if you need help on to happy to show you.
                      Nano CPX, 2 x blade 300x, blade 450 (sk720 FBL), align250
                        look at the 500 pro manual, I believe I have taken those http://ms.align.com.tw/mpeg/manuals/helicopters/KX017015.pdf
                        Sev
                        Trex 450L DFC BD3SX
                        Trex 150 PRO DFC
                        Blade Nano CP X
                        Blade mCP X v2
                        Blade 130X
                        DJI Inspire 1
                        Futaba 18MZ
                        MK Heli Club MKMAA
                        Proud Owner of:
