Hi, this is my first time setting up a 3gx, but i am having a problem i have o% at mid stick and +12% at high but at low i have -18% just wondering how do i adjust it to get it even. Also at what stage of the 3gx setup do i put in normal pitch curve e.g in normal mode 40% 45% 50% 75% 100% and in idle 0% 25% 50% 75% 100%. I am currently setting up with a 0% 25% 50% 75% 100% on normal mode.
3gx setup help
hi first of all which version are you running of software? there have been various tips and setup posts. have a look threw 3gx section posts by coolice or Alistarc and others normally had give good advice/ setup info. the last one I done was V2.1 I think and has changed / evolved. also if your going to run latest version advise to run a good bec as power hungry on standard bec. someone will help further in a bit.Last edited by GIXERMAN; 20-06-2013, 01:41 AM.Santander Factory Team
Proud wearer of 5 x EGS
hi, its v2.1Originally posted by GIXERMAN View Posthi first of all which version are you running of software? there have been various tips and setup posts. have a look threw 3gx section posts by coolice or Alistarc normally had give good advice/ setup info. the last one I done was V2.1 I think and has changed / evolved. also if your going to run latest version advise to run a good bec as power hungry on standard bec. someone will help further in a bit.
3gx setup help
Hi. Your swash is too high. You need to shorten the 3 links between the servos and swashplate. Do all a turn a time and recheck your throw unitl its even. Also check your servo arms are 90 with as little sub trim as possible.Originally posted by CromedCm View PostHi, this is my first time setting up a 3gx, but i am having a problem i have o% at mid stick and +12% at high but a low i have -18% just wondering how do i adjust it to get it even. Also at what stage of the 3gx setup do i put in normal pitch curve e.g in normal mode 40% 45% 50% 75% 100% and in idle 0% 25% 50% 75% 100%. I am currently setting up with a 0% 25% 50% 75% 100% on normal mode.
Make sure you do this in DIR mode and set your pitch curve to 100 50 50 50 0 to make it easier too setup midstick.
When you get it to say +/- 15, reduce the swash pitch mix to bring it down to what you want.
I never use different pitch curves, always straight line, but as a beginner I can understand why you'd want to.
Sent from my BlackBerry 9900 using Tapatalk- Futaba T14SG
- NEW!! TREX 500 Pro DFC 3GX V4.0
- TREX 700e V1 Hybrid 3GX V4.0
Team Mastercard
3gx setup help
Check out the freddy can fly vids on YouTube. They are the best 3GX setup vids I found.. There's four in the series.. Here's the first.
http://youtu.be/MiHpiMnJPQsTom
Hey.
I'll chime in later. Got a customer just arrived to setup their 3GX on V3.1.
But very quickly sounds like your servo arms may not be level at mid stick, so giving an imbalance in pitch range if I'm reading your post right.
.Ian Contessa
Coolice Power Supplies
So i have know raised the swash plate and have got + and - 12% for my pitch. But i am wondering can i now change my normal pitch curve to 40% 45% 50% 75% 100% just for hovering and for 3d have a 0% 25% 50% 75% 100% in idle upLast edited by CromedCm; 20-06-2013, 12:55 PM.
