Need more cyclic response.
    As others have said, don't use any of the preset 'behaviors' in parameter menu B, set it to transmitter (blue light on mine - ver. 2)
    Then you have the travel adjusts and expo to play around with in the TX. I have 30% expo and travel settings of 110 on the aileron (DX7) and it's quick enough for the moves I'm doing but not at all twitchy.
      Okay, Thanks people, Will try it out tomorrow morning
        Let us know how you get on
        If you still feel its not fast enough up the travel some more but 110 is enough for me at my current level and i'm nowhere near you
        DX8
        Phoenix
        RealFlight 7
        Mcpx BL
        Trex 550 DFC with Vx1n
        Trex 700 DFC Pro Hv with Vx1n
        Zmr250 mini H Quad racer
          Isnt there a cyclic response parameter you can set as well, the same as youd set everything to tx controller in the menus of the BX?
          TT Raptor G4 + Vbar
            On the regular BeastX there is a pot that controls the mix of direct stick fed to the servos vs the control loop but I don't think that changes the cyclic rates.
