OS55 won't fire up
  • OS55 won't fire up
    Last time out the 55 fired up and died for no reason shortly after...restarted then failed in flight with a bounced auto and found a cracked ElyQ case..wondered about failsafe cutting in..
    Fixed up the very minor damage... 2 popped links and the reg case but the darned thing won't fire up..
    It's got recent new fuel lines and pressurising the pressure line pours fuel out the fuel line to carb. Pull either needle and fule easily runs out through those seats. Obviously tried new plug and plugs test/glow bright.
    If I force fuel into the carb then pull the plug I do get a spray out of the chamber but not with standard needle setting and normal pressure line. Plenty compression - even managed to hydrolock it by forcing fuel into the carb with the hand pump..
    Throttle servo working fine and no progam changes.
    I'm going to have to pull the engine and dismantle the carb unless anyone has a bright idea?
    PGK
    I had this with my 91 recently (non pumped) was a melter piston crown , too lean bad me !!!!!!!!
    hope I am wrong ;-)
      Have you checked the low voltage output cables from the elyq reg to the glow ignitor, or from yoru remote glow to teh actual glow plug. Just a thought as I've seen this before.
      Otherwise, it might be an engine strip to see if there is anything shot, like piston ring, crown etc.
      Hope you find the problem
      Gav
      Gavin
      • Thunder Tiger Raptor G4 FBL - OS105 HZ-R, Bavarian Demon 3SX, MKS HBL HV Servos, Reactor HVX, Optifuel SLV 25%
      • Thunder Tiger Raptor E720 FBL. Bavarian Demon 3X, (Under Construction)
      • Gaui X7 - (Under Construction)
      • Synergy N5CTT - OS55 HZ-R, Bavarian Demon 3X, (Under Construction)
      • Gaui X5 Formula - XNova 4025-1100, Castle Talon 120HV ESC, Bavarian Demon 3X, MKS BLS Servos, Spin Black Belts, Optipower 6S 4300's
      • KDS Agile 5.5 - XNova 4025-1100 Motor, Castle Talon 120HV ESC, Rail 556's, Optipower 6S 5000 Ultras
      • JR Vibe 50 FBL Nitro (Retired!)
      Optifuel * Bavarian Demon * MKS Servo Tech * Optipower
      http://www.kaos-rc.co.uk
        hope I am wrong ;-)
        I've cooked more then my share engines..:-(... looks fine down the plug port and compression with the starter feels too good for that. But as they say' If you have air, fue,l compression and a spark it should run' - just feel it's lack of fuel but looks like engine out time or just fly a different heli (except that the gasser is cutting in flips and the 700 has a weird wag, both 450's need work and the bitz is a bit pricey for trying new stuff on..: = charging 500 batts)
        PGK
          Gav
          Actually I haven't and I haven't tried firing it with a glowstick (it's charging at the moment) But the remote glow is buzzing well so picking up continuity and enough power to do that bit of it's job..
          PGK
            Check the power to glow plug !
            Raptor E700
            Raptor G4
              I started my 700 the other day and as soon as i turned glow off it eouldnt start again, turned out to be plug, switchglo was buzzing though
              Chris 'CHUNK' Newby
              ALIGN-TREX.CO.UK team pilot
              LYNX team pilot
              SPARTAN team pilot
              Dx18
                I'll try it with the glow stick when i get a mo' .. certainly when i checked the plug via a one cell battery it glowed perfectly...
                PGK
                  Plugs can glow ok off glow stick but not enough under compression,
                  I also found with one of my 55s it needs 1.8volts to the glow for it to fire up, but that could be due to a bad remote lead, runs really smooth when started.
                  55s are notorious for getting and keeping the sweet tuning spot, and rear bearing ware seems to affect the tuning more than others,
                  Tripler/Helipete/
                  "I love the smell of nitro in the morning" & the odd electrickery thingy's
                    I have got the same problem with my 55, tried doing the usual fuel lines etc and it still packs up in flight, think it could be rust on the bearing and particles of it knocking the plug out, so going too fit a new bearing......
                      I finally got around to pulling the engine ..a real mare to get the liner out of this one. It looks like a stuck ring problem - probbaly some debris from the early bearing corrosion aggravated that? I'll try saking the piston top overnight in wd40 otherwise there's no option i can see apart from picking at the join with a pin..which risks damaging the groove and ring pin?? Unless anyone has a better idea such as heat/cool cycles that might actually work...
                      PGK
                        we had a similar scenario last week, ended up breaking the pin out and replacing
                        Chris 'CHUNK' Newby
                        LYNX team pilot
                        SPARTAN team pilot
                        Dx18
                          ..makes me wish i still had access to my ultrasonic cleaners...:-(
                          PGK
                            Might be a silly question, but have you tried a new glow plug in it?
                              ..first thing that was tried wasa different plug. Admittedly that wasn't new (cos i mislaid my card of 12 with moving house - found it yesterday) but both plugs tested fine with a glowstick. Ring is definately stuck and bearing needed a change.
                              PGK
