Originally posted by ddracer
View Post
Wasted power!
Henseleit TDRV-Bar x2
SAB Goblin 700 V-Bar
T-Rex 700e DFC V-Bar
Synergy N7 V-Bar OS105 HZ-R
Synergy E7se V-Bar
Synergy N5c FBL V-Bar
Gaui NX7 V-Bar YS91 Tareq SRX
T-Rex 550 E FBL V-Bar
Gaui NX4 V-Bar
Without Dyno testing the engine properly its guesswork really. When CY was working on various headers for his MP series this was one of the questions he was asked. Why the exhaust port was not matched?.
With the pipe/engine in question it performed best un-flowed.
Best power is usually a combination of small gains throughout the engine/pipe system
Tuned Pipes. We used these mostly in Europe as high Nitro fuel was to expensive or just plain unobtainable back then.
Something to consider when looking at a full pipe system is the overall weight increase and added momentium. You can quicky lose that power gain.
Brian
UPDATE!
Finally I got to fly the header that Rctintin sent me for my Hatori 946 this weekend. I had been trying for weeks, but what with my old 937 falling apart, the appauling weather we've had down here just lately, and other personal commitments I've just not had the opportunity to get some back to back flights to be able to fly both the stadard header and this one. I first had a tank on the original header, where i leaned the mid 2 clicks, and it was stonking. Landed, changed over headers then flew again. Initial thoughts? Top end power seems to have improved quite a lot; the engine just sits there singing away while performing some very fast aileron tic-tocs, quite impressive. The mid range torque seems to be down a tad, but i must admit i think i could lean the mid a bit more; ill play with this a bit more at the weekendIt seemed to have more tope end power overal, but when it did bog through over-pitching, it seemed to fall off the torque a bit more than before. Overall, worth doing for sure, and I'm in no hurry to take it off
Good to get a report back and I guess it backs up what has been said during the thread, from your initial findings it would seem that a good pilot with good collective management would benefit more, as the chances of bogging down the head are less. Looking forward to more info as you put a few more flights on it.Rob
TDR (in progress)
SAB Goblin 700
Vibe 90SG Vibe 500E
Kalt Baron30
Glad you are getting on with it ok Jamie, I look forward to more updates as you get more milage out of it. It will be interesting to know if it has affected your fuel consumption as well.
Keep up the good work Mr Tester!
Cheers dude, RobHenseleit TDRV-Bar x2
Synergy E7se V-Bar
Gaui NX4 V-Bar
EnjoyHenseleit TDRV-Bar x2
Synergy E7se V-Bar
Gaui NX4 V-Bar
