Hi All,
For those of you that are keen to get your hands on the New YS 56 SR this might be of interest to you.
Today I picked up one of these motor's from 'Probuild'. Below are a few piccy's i've taken of the motor straight out of the box and just before installation into my trusty Trex 600 SNP
First impressions is typically YS. Good quality!!! Well packaged very similar to the 91. Looks very similar to the 50 apart from the difference to the carb. This one has 3 needles although only looks like it has two. The low needle is next to the throttle arm. I will be setting this up as per the manual for the first 2-3 tanks (as recommended by the manual) then will start see what power I can get out of it.
I'm running a Hatori pipe also supplied by Probuild. The pipe (562) is recommended for the trex 600n but not the 3D pipe(566). Unfortually they had just sold the last one. Hopefully will get one in the next batch.
Hope this is of interest to you guys
