Originally posted by waveydavey
View Post
align 700 / align 91H engine question
are you confusing pinch with compression here?? I always felt ring engines had more compression. But ABC's have loads of pinch which feels like compression when you turn it, but not if you put a guage on topSome say my left nipple is the shape of a Raptor canopy.......... And that for fun I chase sheep in wellies 3 sizes too big. All I know is I am 3D Clod
Collector of SAB Goblins
You're right I'm thinking of the pinch on the ABC engines - used to run OPS PRO fully gasflowed and tuned within an inch of its life and it had a lot of 'pinch' with new piston and liner.
The 91H has little compression when turned over by hand but produces loads of power and is nigh impossible to turn over hot and wet (no puns please lol)Goblin 570
Goblin 700
Goblin 770
I made an adapter Panos. and use a motorbike compression guageSome say my left nipple is the shape of a Raptor canopy.......... And that for fun I chase sheep in wellies 3 sizes too big. All I know is I am 3D Clod
about 7:1-9:1 is a good figure for a 2 stroke mateSome say my left nipple is the shape of a Raptor canopy.......... And that for fun I chase sheep in wellies 3 sizes too big. All I know is I am 3D Clod
Crank finally out, was easy in the end could grip the fan with a rag and undo the nut with a socket. No locking tools needed.
Bit stuck with the carb though, I cannot get it out. The pinch nuts are out and the carb will rotate, but it will not pull away from the crank case.
Any ideas. I cannot put it in the oven with the carb on
Goblin 570
Goblin 700
Goblin 770
