Upgrade from DX7 to DX7S
  • Upgrade from DX7 to DX7S
    I'm thinking of upgrading from DX7 to DX7S. For telemetry, DSM2 and DSM-X, throttle activated timer and SD card. I was thinking of about £70 for the old DX7 which has a LiFe battery fitted. Does this sound about right? Is there anything on the DX7S that I should know about?
    Blade 130-X, MSR, MSRX
    Phoenix Sim
    Tell u wot give me 50 and the 7 for a dx8
    Trex 600nsp vbar
    trex 500 esp
    Logo400se R.I.P (Resting in pieces)
    hk450 4s beastx
    Lynx heli hybrid 130x
    DX8
      I did just that a while back (but I am still flying with the DX7 and just use the 7S on the sim so far). At first I was a bit put off by the crude looking graphics in the 7S but at the end of the day it's about the function first.
      If you're used to using both idle-up modes on the 7, you only have one on the 7S so just your normal mode and one idle-up, but there are a number of ways to use other switches to get another throttle setting etc. so it would only be an issue if you really make thorough use of both idle-up modes.
        Yeah the DX7S only has the two Idle settings, which I wasn't aware of when I first bought mine. However I don't see it as an issue at all, I see no need to switch between headspeeds at all. I certainly wouldn't upgrade to the DX8, I'd happily upgrade to the new DX9 or the DX18
          Yeah it's no biggie for me because the only time I use more than one idle-up it's only the headspeed that changes as I leave everything else the same. So on some of the electric helis I want a low headspeed 'stunt mode' with idle-up and full pitch range and then the idle-2 switch for the full-on ballistic headspeed and this would be easy to get using another switch on the 7S. I have mainly just been lazy about moving over all my model settings so I can start flying with it.
            I did the upgrade from dx7 to 7s and regret i didnt just go for the dx8. With not having a 3 position idle switch it gets annoying having to go from hover headspeed to full 3d head speed n nothing in between
            Trex 550L Gpro
            Trex 550 vbar night flyer
            Revolectrix PL8/MPA/Silver 5500 packs
            Spektrum DX9
            RealFlight 6.5
              so is 70 quid about right for a dx7 ?? thinking of an upgrade myself
                Sounds ok then. Thanks for all the info.
                Phoenix Sim
                  The 7s looks so much better than the 7! Im useless with programming and even i find it easy to programme helis on the 7s! You wont miss the 7
                    Does the DX7s work in DSM2. I thought it did, but perhaps that's only for an upgraded DX7. I have some DSM2 stuff. mcx and msr and rxs as well.
                    Phoenix Sim
