have a look
Spektrum: DX9 Transmitter
Features:
Programming Features
Features:
- DX9 Features
- 10 Aeroplane Wing Types
- 6 Aeroplane Tail Types
- 6 Swash Plate Types
- 5 Aeroplane/Heli Modes
- 10 Sailplane Modes
- Dual Diversity Antenna
- Full 9-channel support
- Expanded switch and channel assignment
- Proportional levers on back
- Range check
- Timer – throttle or switch start
- Servo monitor
- Aircraft, helicopter and sailplane model types
- Wireless trainer system
- Virtually unlimited model memory
- Balance feature available on all channels
- 10 programmable curve type mixes
- High resolution 192x96 LCD (DX8 size screen, higher resolution)
- Modes are selectable from 1 to 4 so that one radio covers all modes
- SD card included- user can see on the display update version
- Direct system menu access
- Voice annunciation- allows telemetry and warning voice annunciation
- 3-axis gyro support for aircraft-allows adjustment of gyro gain for all 3 axis in flight
- Language selection- select from 5 languages; English, German, Spanish, Italian, and French
- Active gyro and governor trim in heli, active gyro in aircraft (allows adjustment in flight)
- Real time telemetry- radio will display real time flight log data
- Absolute travel
- 7 point curves- ability to fine tune model setups to allow precision adjustments of mixes andpitch/throttle curves
- Helicopter Electronic “E Ring”- electronically prevents overdriving the cyclic servos
- Programmable flap system with flap delay and elevator compensation
- What’s Included
- 2000mAh 2S Li-Ion transmitter battery (installed)
- SD Card
- Custom DX9 neck strap
- 12V Global Power Supply
- Aeroplane
- 10 Wing types: Normal, Dual Aileron, Flaperon, 1 Aileron 1 Flap,
1 Aileron 2 Flaps, 2 Aileron 1 Flap, 2 Aileron 2 Flaps, Elevon,
Elevon-B, 4 Aileron - 6 Tail types: Normal, V-Tail A, V-Tail B, Dual Elevator,
Dual Rudder, Dual Rudder/Elevator - Flap delay and elevator compensation
- 5 Flight modes
- Dual rates and expo
- 10 Programmable mixes
- Helicopter
- Active gyro trim
- 7-Point throttle curve
- 7-Point pitch curve
- 7-Point tail curve
- 7 Swashplate types: Normal, 3 Servos 120º, 3 Servos 135º,
3 Servos 140º, 3 Servos 90º, 4 Servos 90º, 2 Servos 180º - Swashplate timing
- 5 Flight modes
- Sailplane
- 5 Wing types: 1 Servo, 2 Aileron, 2 Aileron 1 Flap, 2 Aileron 2
Flap, 4 Aileron 2 Flap - 3 Tail types: Normal V-Tail A, V-Tail B
- 10 Flight modes
