I'm still trying to set up a CGY750,AR8000 receiver and Castle 120HV ESC and have a problem with throttle hold.
It seems even with throttle hold activated it is still causing the motor to run.
So you move the throttle stick to start the motor and when up to speed throttle hold is activated.
The motor does not stop but speeds up and if you look at the RPM's being monitored on the CGY's screen you can see a head speed displayed.
Normal mode in the governor is 1750rpm and with hold thrown the motor displays about 1800rpm and switching back and forth displays the different speeds.
There is an option in governor menu in the TX for throttle hold.Changing the value in here doesn't stop the problem.
It's as if there is a throttle curve for 'Throttle Hold' somewhere that has got values in it.
Missing something else here but don't know what.Any ideas?
