14sg
  • 14sg
    The update for the 14SG is now up on the Futaba website.
    Version 1.4
    Member of Mk Heli Club
    How often do futaba have these updates. I have never updated a TX before but will do it to keep it up to date
      Flip, not even had mine a month yet.
      Raptor 30V1 Maverick Head
      OctoCopter
      Futaba 14SG
        Link Futaba® Software Downloads/Updates
        OctoCopter
        Futaba 14SG
          Just reviewed the update and can't be bothered to do it, there's nothing worth doing the update for, see the bottom of the PDF below
          http://downloads.hobbico.com/softwar...update_WEB.pdf
          OctoCopter
          Futaba 14SG
            Depends on what it is for. There is still the use of the earphone socket to be enabled. Generally though they are not that often.
            Read the PDF file and do exactly what it says. It works perfectly. If you have any trouble then you have not followed the procedure. For me the only minor thing is knowing which drive is the SD card slot on a multi card reader that displays 4 different drive letters. Ignore any Windows prompts regarding scanning, fixing or anything as the SD card will have the Futaba format on it.
              This is just to bring the previously released radios up to the same version that will be released in the USA any moment now.
                I have just seen, that indeed the radios already delivered in the USA are at version 1.4.
                  So the question is when will the "real" update be out that enables the earphone socket and any other magic that Futaba have been working on?
                    Good question, unfortunately Robbe have a bit of a reputation for publishing expectations rather than facts when it comes to unannounced Futaba material so I wouldn't be depending on any schedule coming out of Germany right now.
