Help setting up Futaba 14SG
  • Help setting up Futaba 14SG
    Right, just about to set up my first Futaba radio to a generic FBL unit.
    I only have wires as supplied by the FBL unit which can allow for all set ups?
    Where to start lol
    What's the fbl unit Ben ?
    Glenn
    logo 600se
    700 N dfc
    700 dfc
      If you are using V-bar, then just turn on your Tx, and then power up the Rx, and press the button in on it till the red led turns green.
      Now follow the s-bus setup as per the V-Bar program.
      Henseleit TDR V-Bar x2
      SAB Goblin 700 V-Bar
      T-Rex 700e DFC V-Bar
      Synergy N7 V-Bar OS105 HZ-R
      Synergy E7se V-Bar
      Synergy N5c FBL V-Bar
      Gaui NX7 V-Bar YS91 Tareq SRX
      T-Rex 550 E FBL V-Bar
      Gaui NX4 V-Bar
        Its not a Vbar.
        I have linked the rx to the tx so good to go there. With Sbus it it the normal male to male 3 pin lead I have here and that goes from no8 to the FBL unit? The servos simply plug in to the 7008 unit, but in what order as its just numbered 1 2 3 4 etc. Still reading
          Ben,
          NO servos get plugged into the RX mate, everything goes into the fbl.
          you have 1 lead going from RX-fbl which it sounds like you have already so your done wiring the rx.
            You will need to check that the FBL unit (whatever it is) has the functions on the same channels as the TX.
            If not then change one or the other accordingly.
              Trying out the Vortex then are you?
              Brave if you are in Spunky!!
              Synergy E7se V-Bar
              Gaui NX4 V-Bar
                Nothing changing in Spunky yet.
                How do I assign the switches on the radio to TH and idle up etc?
                  everything on futaba is done on the condition screen. there will allow you to pick what switch you want to use and what position you want the switch in.
                    Condition select then assign the switch/ on position .
                    Glenn
                    logo 600se
                    700 N dfc
                    700 dfc
                      Getting their lol. Only 3 idle up's?
                      Dont look like I'll be flying tomorrow after all
                        Too many years on the dark side Ben that's your trouble !! Lol
                        Glenn
                        logo 600se
                        700 N dfc
                        700 dfc
                          No mate there are 4 flight modes, Normal plus IU 1,2 & 3
                          Synergy E7se V-Bar
                          Gaui NX4 V-Bar
                            Help connecting R7008SB
                            You should be able to get more than 3 idle ups..
                            I'm sure you can... But then you use more switches..
                            Mark
                            www.uavaerialservices.co.uk
                            BNUCs - Operations certified
                            CAA - Permit for Aerial Work
                              3 will do :sigh: lol.
                              Just got used to using 4 believe it or not.
                              I have assigned the idle ups to how I have them on my DSX11 which is idle up 1 and 2 are on SG and idle 3 is on SE. I have set TH to SF.
                              Does this have to be done on all new models you set up?
