Futaba T7CAP 35mhz to FF7 2.4ghz
  • Futaba T7CAP 35mhz to FF7 2.4ghz
    Hi all, I decided at long last to move over to 2.4ghz and have a FF7 2.4 coming soon. Don't ask why I chose Fubbie, I think part of it was that I thought it should be straight forward to copy settings over, along with some planks I already have on FASST 2.4 with a 6EX will be compatible too.
    So I am correct in that I should be able to copy the settings from the T7 to FF7 manually of course, for my Raptor, or is it not as simple as that? They look identical apart from the frquency?
    Also can you recommend anywhere for the best prices around these days for a FASST 617 RX?
    L̶y̶n̶x̶ ̶3̶8̶0̶X̶L̶ -
    Black Hawk (Helipro) 450
    Blade mSR
    Blade 130X
    Trex 450 SE
    R̶a̶p̶t̶o̶r̶ ̶5̶0̶ ̶T̶i̶t̶a̶n̶ -
    Trex 600 LE
    Trex 500 - crashed pondering repair !
    + Planks too I'm afraid ......
    if anything it will give you a starting point don't think it will be far away
