Yes. It certainly is possible, my uncle is mode one and I've done it with him before.
In reality it will be quicker to set up a new model (and mirror your settings) on the mode 1 radio than try to copy it across, because it'll take you so long to get your head around the sd card transfer, so you may as well just do it the way you know how!
Even if you did get it to work, you would still have to swap over the joystick commands so that it works mode 1. It is complicated.
