Futaba 14SG Low battery volts
  • Futaba 14SG Low battery volts
    Guys, what volts are you suggesting is the bottom line before charging?
    I'm used to the fuel % level on the 18, so need to know the number to look out for on the 14 please.
    Henseleit TDR V-Bar x2
    SAB Goblin 700 V-Bar
    T-Rex 700e DFC V-Bar
    Synergy N7 V-Bar OS105 HZ-R
    Synergy E7se V-Bar
    Synergy N5c FBL V-Bar
    Gaui NX7 V-Bar YS91 Tareq SRX
    T-Rex 550 E FBL V-Bar
    Gaui NX4 V-Bar
    What battery are you using?
    I'm using LiFE and have it set to 6.5V. Stock battery is 6V and cut off is usually 1V per cell, therefore 5V. I'd stay on the safe side and set it to 1.1V per cell, so 5.5V. The LiFe batteries are far better though, I've got a couple of these ones:
    Turnigy nano-tech 2100mAh 2S1P 20C LiFePo4 Transmitter Pack (Futaba T14SG) (UK Warehouse)
    • Futaba T14SG
    • NEW!! TREX 500 Pro DFC 3GX V4.0
    • TREX 700e V1 Hybrid 3GX V4.0
    Team Mastercard
