DX7 failsafes
  • DX7 failsafes
    Just been equipping the Zagi with a AR6100.
    During setup I noticed that I couldn't set a 'throttle to zero and gentle turn' failsafe. It will only do a 'throttle to zero and keep last positions' failsafe.
    I could set a gentle turn failsafe on my Futaba T7C but it seems that I can't on the Spektrum.
    Am I missing something or does the Spektrum only support 'keep last position' ?
    Cheers, Lee.
    Proud recipient of an EGS
    Had this with my module on my 9X2 seems they only support hold on all channels bar throttle. Bit stupid but never mind
    Phil
      Spektrum only has a failsafe for the throttle, all other channels will hold last posistion.
      You must rebind after setting up a model so that the failsafe is in the correct posistion for the thottle (closed or idle).
      Raptor 50 V3 Titan
      Trex 600N Pro R.I.P
      Knight 3D
      Trex SEV2
        Cheers Phil & Leon, nice to know I'm not missing the obvious. I agree with you Phil - it's a bit daft and an oversight in my book.
        Cheers, Lee.
          Seems daft to me but what do I know
          Phil
            Agree the lack of flexibility in the fail safe is not good.
            But on a zagi, how can you set throttle off and gentle turn?
            Surely if you have a bit of aileron what you have is a very slow roll!
            ...which combined with a little up elevator will be a slow half barrel roll and incomplete half loop into the ground...(Probably).
              You're right. I was thinking of a hint of aileron and up elevator and, with no throttle, I was going for a gentle turn - gentle stall - gentle turn and so on. Having said that, the amount of time that my zagi actually spends straight and level during a flight, a throttle to idle failsafe might be the only way to go.
              Cheers, Lee.
