DX7 & Revlock 20 set-up.
  • DX7 & Revlock 20 set-up.
    This might come in useful for anyone using a Revlock 20 who wants the flight mode switch to control it.
    I used the advice in another post from Ade I think, and another thread at Raptor technique to set normal mode to gov disabled, idle1 to 1850rpm, idle2 to 2000.
    But I wanted to try using the limiter function of the RL20. This turned out to be a bit more tricky because both my idle settings were in mode 'A' on the gov.
    I've now found a way to set idle 1 to mode 'A', & idle 2 to mode 'B'. I can now set mode 'B' to limiter mode. (once the postman gets round to delivering the USB cable ).
    This is how I did it.
    (INPUT SELECT)
    AUX 2 - F.MOD
    (TRAVEL ADJUST)
    AUX 2
    +81%
    -38%
    (SUB TRIM)
    AUX 2
    -102
    CHANNEL 7 Reversed
    These settings (or something close) will give Gov off in normal, 1850 (ish) idle 1, 2000 (ish) idle 2. All in Revlock mode 'A'.
    The prog mixes below enable mode 'B' in idle 2.
    (PROG MIX 1)
    AUX 2-AUX 2
    RATE: -22%
    0%
    SW:F-NR
    OFFSET: 0
    (PROG MIX 3)
    AUX 2 - AUX 2
    RATE: 0%
    -125%
    SW: F-S2
    OFFSET: +125
    Obviously you'll have to fiddle with these a bit depending on the speeds you want to run but it works!
    Hope someone finds this useful
    Ian
    Knight 3D
    Velocity 50
