Spectrum problems Poll
  • #31
    I've well over 600 flights on DX7 never had any hits.
    Low voltage resets. Fromeco and Spektum offer a capacitor that prevents sudden voltage spikes causing Re-sets that can be used if necessary. Personally I'm running a Regulated system on my Nitro's
    My own preference is for the dual link Rx's. The AR7000 being what I use. The 7000 is actually deceptively light..about 1/3rd of the weight of a standard 8ch Rx and even my Mini Titan doesn't notice it's there..
    SPARTANRC Team pilot
    • #32
      Glad this thread has surfaced again,i am still having zero problems..
      Martin
      I run the 6100 on the 450V2 and its fine on the bec power supply from the esc,the 6200 is as good as the 7000 ..
      I would use 6200`s on all models that require up to 6 channels and 6100`s on 450`s and foam planes
      The DX6 is not compatible with the DSM2 Rx`s and has a shorter range
      The new DX6i is full range and DSM2 compliant
      • #33
        the DX6i is the one i was gonna get with the blade 400 but i got a belt cp for now instead and glad i did but i need to get a good TX while i can. the DX6i isn't launched yet so its got to be the DX7. as far as i know the DX6i doesn't have any advantages over the 7.
        joe
        • #34
          I use a 4300 sub c nimh and keep it topped up and i have digital servos all round, and I am starting to hammer it now. no problems yet. I did put a 4700 capacitor on the supply though.
          • #35
            Had mine 12 months now - never had a moments doubt - never been so relaxed when flying electrics.
            Dave
            • #36
              Getting on for between 30 and 40 flights with a DX7 & AR6200 in my Mini T using stock ESC for onboard electrics. Not so much as a glitch so far (touches wood). Beginner, so hovering and slow figure 8s only so far.
              Bill
              Mini Titan E325
              • #37
                I have been on Spektrum for about a year now (maybe a little longer), I have 9 Models on Spektrum and 3 on 35Mhz, the only suspected issues I had was with the AR6100 in my Trex 450, there was some unexplained crashes but since I got it swapped to the V1.2 it has been flawless, I have 3 models on AR6100 (V1.2) and 6 models on AR7000.
                Raptor 50 V3 Titan
                Trex 600N Pro R.I.P
                Knight 3D
                Trex SEV2
                • #38
                  I want to move to Spektrum, but this lockout/Rx power supply issue is a worry to me.
                  I have a Trex450 on4S and the BEC is in a Jazz.
                  Anyone, know of any issue with the Jazz supplying watered down main Lipo power for the radio gear?
                  450SE Silver - Power: Neu1107-2Y + 10t pinion
                  ESC: Jazz 40-6-18 Gov.- Batts: 4s, FP 2100 20C. pitch +/- 11 (TC60 PC 0,25,50,75,100) HS2900
                  HS65Mg x3 + GY401 + S9650 tail
                  Rx: AR6200 - Tx: FF9Super(T9CP) Spektrum module
                  Progress Status - aggressive fff and loops
                  Crash count = 10 for 153
                  Trex time aloft = 19:45
                  -Twister Cp - Yuk!
                  -Blade CX2 - Yay
                  • #39
                    Not a problem Rick. I run 4s with a Jazz and a 6200 rx without any issues at all.
                    Ian
                    Knight 3D
                    Velocity 50
                    • #40
                      I too run a 450V2 with Jazz on 4S and an AR6100 V1.2 never had a problem.
                      Raptor 50 V3 Titan
                      Trex 600N Pro R.I.P
                      Knight 3D
                      Trex SEV2
