Jr X2610
  • Jr X2610
    I am trying to setup my robbe peak power ultimate charger to charge the transmitter but i need to know the discharge and charge current. Can anyone help please.
    Raptor 50 Titan
    OS 50 Hyper
    CY MP5
    What is the battery eg 2100 mahs ets etc
      9.6v 600mAh
      Dan
      Raptor 50 Titan
      OS 50 Hyper
      CY MP5
        You can't charge & discharge it in the transmitter with the Robbe charger as there is a diode in the charge circuit inside the transmitter so the charger can't 'see' the battery, when you try to charge you will get an error something like no battery connected. The best way around this is to use a small wire link and solder it across the diode, thats the route I went with my 2610 and 9X.
        Steve H
          Hmm looks like this ebay guy as proper shafted me. It was meant to be ready to fly. It arrived with the tail control rod snapped, no training undercarrage like he said, a charger that wont charge my tx and the 12v battery to run ther charger has no charger itself and it is flat.
          Raptor 50 Titan
          OS 50 Hyper
          CY MP5
            its quite common that a fast charger wont charge whilst in the controller, futaba FF8 for example, doesnt matter though take it out, and find the connector at your local hobby store and bobs your uncle,
            600 mah wont last that long, you should consider something a bit bigger my 2100 will go for a couple of hours flying before recharging
