RX repairs
  • RX repairs
    Has anyone had to send away receivers to be repaired?
    Got two FP-R138DF which needs repairing.
    send them back to Ripmax or is there anthor place which repairs them?
    both need new aerials and 1 needs a new case
    Hi mate
    Try this place there spot on with work on radio's.
    http://modelradioworkshop.co.uk/
      i doubt repairing a 138df is worthwhile. the schulze/hyperion rx's are better as they are DSP also a lot smaller. only around 45ukp.
      i cant see an rx repair costing much less than that.
      Ade
      www.accurc.com
      adrian@accurc.com
      This is an apple free zone
        ive got 1 of those on my TREX and they are good must admit
        ill get a costing and way the options
          DIY -- Aerial replacement is a simple soldering job -- or find someone who can.
          Dave
            Whats the wire gauge any idea, no problems with soldering the wire
              anything really just has to be the right length
              Ade
              www.accurc.com
              adrian@accurc.com
                Hi try this place i get my aerials from them.
                http://www.grimsbymodelcentre.fsnet.co.uk/
                Best to get the futaba type wire for your rx.Not just anything will do ?
                There around £1 per aerial.
                  Speaking with my licensed radio amateur hat on - the antenna is simply a piece of wire cut to a known fraction of the wavelength of 35MHz (actually quite a small fraction since the wavelength of 35MHz is about 8.5m or so). A half wave antenna would be very efficient, but still 4.25m long - still totally impractical for a model heli Wire guage is completely irrelevant, although I'd use a copper stranded wire rather than aluminium, or single core stuff. If it really must be orange, buy the Futaba-marketed wire - or go to Maplins; they do a range of colours.
                  Cheers - Rob.
                  T-Rex 600CF-E * GY601 Gyro * S9251 digital Tail * S3152 digital Cyclic * 2x 4800 Aurorra LiPos * 600L Motor * TT composite 600mm blades
                  3DX-400 Hybrid parts bin special * GY401 Gyro * Robbe 0.054sec digital tail * All CF/Aluminium construction bar plastic main gear
                  Wren MW54 Gas turbine Jet-1 trainer * FF9 Super Radio * Phoenix Sim * Understanding wife * Unhappy bank manager
                    Are you sure orange is the best i thaught the pignemt in the plastic made into a semiconductor so it converted the
                    wire into coax and shelded it completly and thats what stopped it working.
                    Steve
                    Brown is best as it is by definition single core.....
                    Steve...
                    Outrage RC Field Rep
                      umm...
                      Dielectric constant of various plastics could make a difference, but I would have thought PVC was PVC?
                      Cheers - Rob
                        Ahhh but because its brown not orange it can be described quit e accuratly as being at one with itself an orange one is by the same inference not.... Surely a blue one with a purple stripe could be describesd as being all sixes and sevens......
                        Steve
                        Steve...
                          did someone a little while ago have some hyperion receivers for sale? cant remeber who it was,
                          whoever it was have you still got them for sale?
                            My local model shop sells Futaba replacement aerials (orange) - They can't be the only ones .
                            Dave
                              Dave
                              My LHS sells them too and there genuine Futaba!
                              Raptor 50 V3 Titan
                              Trex 600N Pro R.I.P
                              Knight 3D
                              Trex SEV2
