dx6i
  • dx6i
    round the mother in laws, and no manual
    I want to change the expo lower, to make it a tad more sensitive, its on 20, so say 10 ok
    if i want to adjust the gyro for that slight tail wag i have i go into the gyro menu??? there is inh or something and something else, what do i have to do to adjust the gain on this???? silly forgetting the book i know
    Special sponsorship and donation by
    and so many members of this great forum
    you guys will never know how much i appreciate your help
    Go into the gyro menu and turn INH to GYRO
    This allocates two settings to channel 5 (the flap gyro switch) One for Rate and one for HH.
    Then just set the two % as required.
    Graham
    Phoenix, DX6i.
    x2
      inh to act is what it does
        my gyro is set on the gear switch so when i switch on the gear it is in HH and then i use the travel adj to set the gain.
        Trex 550e dfc :-)
        t-rex 450s x2 /Raptor 50
        kyosho spree small plank
        bogey combat plank x2 woop
        http://www.cuffleymfc.co.uk
          1st, Are you sure your in the gyro menu
          2nd, Is this for your 450 or for Phoenix?
          Graham
          Phoenix, DX6i.
          x2
            its for the 450, in the main menu, there is dual rate/expo, done that, under that menu heading is gyro. Am i in the wrong place??
              I can't remember the dx6, but surely not a sensible idea to try assisting gyro gain away from the heli
              Kev
                Ahhh, No, your in the right place but I suspect yours is set up the same way as Brins and that's why its showing INH.
                Graham
                Phoenix, DX6i.
                x2
                  it has a tail wag on hh, someone suggested turning it down a bit, i got into the menu, ok,
                  0 = 50.00
                  1 = 50.00
                  same figure, 0 is the hh, maybe 45-48%, it doesnt need much i think
                    0 = 50.00
                    1 = 50.00
                    Andy, you need to go back and set the gyro menu to INH (See my previous post)
                    Graham
                    Phoenix, DX6i.
                    x2
                      il see what it does for now, i googled an online manual, click on inh, this then allows u to change to act, click on that, you get the gain settings, but i see what your saying, thanks Graham
                      ive changed the tt gears, lubed it all up, that might help anyway as its all quite stiff and new
