Hi everyone,
trying to set up my dx8 on programmable master to a dx7 slave. So far i have everything to work ok except for the tail which is fine on my dx8 but when you push the trainer button the tail slides all the way across and will not hold in hh mode. When you put the dx7 into rate mode its fine. Also if you hold the trainer button while powering up the heli it will work fine on the dx7 but not on the dx8 (same tail slider problem)
any ideas?
any ideas?
