dx6i binding .... help
  • dx6i binding .... help
    if i change any setting on my dx6i (expo/dual rates) do i have to re bind my transmitter to the heli or will these settings be adjusted without re binding ???
    only had blade 400 for a cpl of days but great fun !!!
    Blade MSR
    Blade 400
    Blade MCP X
    Dx6i
    Phoenix sim
    Generally not but, from what I understand, if you are tinkering around with gyro settings etc, re-binding is not a bad idea.
    It only takes seconds to do and can, in general terms, do no harm.
    Martin
      This only affects fail safe. Most fail safe is continue as yuo were. It affects start up if you switch on the rx first. Can be a problem if you have a very low throttle hold and switch on with throttle hold on. Then if throttle trim is central the heli will start to turn when you take throttle hold off.
      Chris
      Blade 130-X, MSR, MSRX
      Phoenix Sim
