Swash level.
  • Swash level.
    My swash on one of my 700 is not moving up and down level when I go from full + to full-.
    On the DX7 all I did was to go to my travel end points and adjust the value. Is there another way to do this on the 12X??
    Thanks Arwel.
    Trex 700n DFC.
    Trex 700e TOP.
    Trex 700e Pro.
    Trex 600n DFC.
    Vbar Controller.
    Think swash expo is supposed to help I think but you will get it a bit with the servo wheels and linkages.
    Sub trims don't help because your causing the servos to go of centre.
    try moving servo wheels to different servo's some times helps
    Cheers Paul
    Citizen #42
      Actually just the same as the DX7. Having set middle 0 degrees swash level at 50% stick, you move the stick fully up and use Travel Adjust (Section 12 Page H-28 in the DSX12 Manual) to level the swash at Max pitch, then move the stick fully down and do the same, level the swash using Travel Adjust. Then in the Swash Mix set the EXP: to ON (Page H-40 and H-41).
      Edmund
      All Electric:
      Big Plank: Jabiru SK
        If you can actually see the swash is not level as it goes up or down then adjusting the end points is not going to fix it. If that is the case it is possibly due to one of the servos not operating at the same speed as the others. As far as I know the only radio that has mixing to fix that is the 14MZ and maybe the Fut 8FG.
        Member of Mk Heli Club
