Since i have upgrade to the last two versions of firmware i have been unable to assign the gear switch throttle hold. On the pervious version i was able to assign gyro to throttle hold which for some reason was the gear switch. Since i updated to the latest firmware versions this has not been the case. When you assign gyro to hold it now uses the gyro switch on the front of the radio. There is no option for gear under the hold setting. If i look at a old model that was setup prior to these firmware versions i am still able to use the gear switch as a hold switch and under the hold menu it now appers as mix. If look at the other options on the list MIX then disappers.
Hope this makes sense to everybody. Has any body been able to get there hold switches to work and also to work on newly setup models since these new firmware releases.
