Had a very strange moment last night. Guess most of you already know about this but thought I would post what I found in case is helps anyone.
Had been flying the MSR for a couple of packs and then control seemed to get very loose, almost spongey and the blue led kept flashing occasionaly well before the VDC should have kicked in.
Changed the pack, and response even worse and more flashing lights from the blue led.
Scratched my head, thought lets try out those new rechargebles I recently bought.
Voila, handling tight as a drum and back to normal response so guessing that the old batts had got low on charge.
The odd thing though is that I seem to remember that the last time the tx batts were getting low that the tx gave a warning beep, but maybe as I was using the timer it did beep and I misinterpretted as a timer beep?
