Antenna woes (Turbo Antenna)
  • Antenna woes (Turbo Antenna)
    I have been flying for a couple of months with a Turbo aerial which has been fine up untill last night when it snapped in half after managing to dislocate itself from it's heatshrink.
    So I am looking to see if there is an alternative before I buy a new one.
    Anyone know of anything similar that is available? and where from ?
    Thanks in advance
    *edit* seen two over on MidlandH..
    JRC466 : FLEXIBLE ACTIVE AERIAL 35 £24
    Base loaded Aerials £19
    The "Base Loaded" one looks a bit more robust.
    Last edited by jiberjaber; 06-02-2007, 10:43 PM. Reason: added a couple of candidates...
    Regards,
    Jason
    Just one more thing to go wrong.
    Stick with the standard wire aerial from the Rx.
    JR Vibe Fifty fb (YS56)
      Check this thread out
      http://www.rcheliaddict.co.uk/showth...highlight=base
      If you look at my posts there further on down the page you can find insructions to actually make one yourself for virtually nothing - so why pay shop prices for bling when you can get the satisfaction of making something yourself ....and save the pennies for another time
      There's also this debate / stuff on the same subject
      http://www.rcheliaddict.co.uk/showth...ht=base+loaded
      Dave
      Avro Vulcan XH558 - Has now flown !!!
      http://www.tvoc.co.uk
        Thanks Dave.
        I have been running this Turbo jobbie for a few months with no problems with glitching (never had *any* glitches on the Trex!). The Trex was flying ok on Monday night after the antenna fell apart and only the base coil was attached. I range checked it when it fell off and it was a good 25m, i.e. the full length of the gym I was in. No good for being outside hence why I am after replacing.
        I'll take a look at the links Dave has provided.
        Cheers all
        Regards,
        Jason
