10c / 7c Buddy Setup
  • 10c / 7c Buddy Setup
    Chaps,
    Im trying to train a mate but having a few issues with the buddy setup. Im using a 10c as a master with a 7c as a slave. Despite replicating the pitch, throttle, strim, epoint, afr and setting all of the training functions to "func" when i flick the training switch the swash goes off level. I just cant figure whats causing it. Any suggestions on what to check next?
    Thanks in advance
    Trying to progress not getting very far.......
    Am not sure but i did not think you programmed the second transmitter, just plug it in and make sure the servos don't need reversing. probably tottaly wrong. I think you do not turn the second one on just plug it in,
    Velocity 90 FBL Beast x
    Outrage velocity 50 nitro,
    Beam E4
    Futaba 10 CG
      Tried and failed :-( and the manual only seems to tell you how to setup as the master .............
