motor disable on DX6i?
  • motor disable on DX6i?
    How do you disable the motor on a blade 400 in the DX6i? In laymans terms please. I heard something about going full range 0-100 in stunt or something. But that means bugger all to me. I need a step by step noob guide.
    Thank you
    why do you want to do that
    do you mean throttle hold
    adieuk
    x7 eddie gold stars!
    www.eaglerc.co.uk
    dx7, phoenix sim
      I'm rebuilding the head, and want to set it up with the Dx. And I don't really want to faff around unplugging and plugging back in the wires to the esc.
        sorry but the best and safe way is unplug the wires on the motor
        adieuk
        www.eaglerc.co.uk
        dx7, phoenix sim
          Yep, electronics are great, but experience with many types of electrical devices has shown one thing, never trust electronics when it really counts, circuits can do weird things from time to time, best bet is unplug.
          Current kit
          Evo 50
          T-rex 500FG night setup.
          T-rex 700N pro
          T-rex 450 pro
          10CP
          Frankenstarter (dynatron)
            if you dont want to unplug the motor remove the pinion! if your rebuilding then it will be easier too,
            But ur refering to Throttle hold i think once you have the throttle calibrated properly in your throttle curve menu there a curve for hold set that at a flat line at all 5 points and i use 0.5% just to be sure its below the minimum throttle position, this is turned on and off by the top right 2 position switch marked hold.
            if you really get stuck PM me.
            Alex
            Innovation RC Blog
            Innovation-Rc on eBay
            www.heliharry.co.uk
            www.robochallenge.co.uk
            500 ESP. Ely Q Comp, KASAMA'd 600
              i think its easier just to unplug the 3 wires and job done then when finished just plug them back in no changes made
              adieuk
              www.eaglerc.co.uk
              dx7, phoenix sim
                Unplugging the wires is often a faff. I usually use throttle hold (not idle up! You don't want to get them confused!) to disable the motor while setting up/ fettling. However, I can't deny there's a greater chance of injury, and I only really dare do it because I have a long soft start on my ESC.
                If you've any doubt about what you're doing, unplug/ remove the motor!
                Neil H: Certified compatible.
                  I agree with the post's above take no risk's as work around's get you in to bad habits at the field. In any case you should have your thottle hold switch active as its apart of your start up routine. Just imagine you've just put your Blade 400, 450 or even 500 down to fly and then you walk back to the flight line and your pride and joy is now full throttle head your way and you have your back to it. How many times have you or heard other pilots say how lucky they were that they had their throttle hold switch on. Never trust your heli/aircraft just to sit there until you are ready to fly.
                  Mike, 3rd Hampton Scout Group
                  Spectrum DX7
                  Piper Pawnee 40
                  Wot Trainer, OS 46Fx
                  3D 400
                  P68C Scale twin
                  SRCMC
                  Pround owner of an EGS
                    I've always used a Y lead and have an Rx battery handy for setup duty on all my electrics. Saves disconnecting stuff and keeps things nice and safe
                    Phil
                      Pull the leads - you know it makes sense!
                      Martin
                        If your gonna be lazy i hope you got a soft start
                        Fook that,undo 1 grub screw,yes 1,a small,easy job...pop the pinion off,no bandages needed
                          I guess I'll be pulling the wires off then,lol.
                          Thanks all
                          Its all back together now. Just needs setting up and I'm flying again! Battery number 3 here I come
