After leveling the swash plate at 0 pitch, I have found two DX6i transmitters will only allow one end to be adjusted, when trying to level the swash plate at top and bottom.
The manual states:-
The Travel Adjust function allows the precise end-point adjustments of all six channels in each direction independently. The travel adjust range is from 0–125%.
Channels available for programming are:
• THRO: Throttle
• AILE: Aileron
• ELEV: Elevator
• RUDD: Rudder
• GYRO: Gyro gain
• PITCH: Pitch
While the screen shows the values changing, the servo's remain in the same position.
Has anyone else experienced this issue before?
The manual states:-
• THRO: Throttle
• AILE: Aileron
• ELEV: Elevator
• RUDD: Rudder
• GYRO: Gyro gain
• PITCH: Pitch
