DSX9 Timer
  • DSX9 Timer
    Does anyone know how to setup the timer on the DSX9
    • Flickr Through My Pictures.
    I don't have mine with me but i am sure it's quite straightforward. If you can't see it in the main menu it might be in the menu you access when holding a button and turning it on. I have my timer set up on the throttle cut switch, opposite side to the throttle hold switch. Do you not have the manual handy? If so RTFM
      If you have the manual it is on page 173 how to use the timer. The manual has bits of useful info in the other sections like timer is under sailplane section, worth a flick through the sections.
      David
      Kyosho Concept 30 still going just
      T Rex 450 V1 GY401
      T Rex 450 Pro FBL DFC AR7200BX
      T Rex 600n compass FBL head Vortex N
      Srimok 90N FBL VX1
      A EGS for me shucks X 2 to treasure.
        Found it!! downloaded the manual
          You mean to tell us that you pay a fortune for a DSX9 and you dont get a manual
            I've got the manual but left it at home I was at work at the time, manage to find a site to download the manual pdf.
