Ar7000 receiver setup
  • Ar7000 receiver setup
    Could anyone help me please?
    I have a Spektrum Ar7000 receiver and hitec 5245mg servos and a futaba Gy401 gyro with a Futaba s9254 tail servo.So what plugs where on the Receiver?
    Cheers Grant
    Proud owner of 2 Eddie Gold Stars!
    Channel 1: Throttle
    Channel 2. Aileron
    Channel 3. Elevator
    Channel 4. Rudder (Plug the gyro in here)
    Channel 5. Gyro gain (Plug the yellow gyro lead in here)
    Channel 6. Pitch (Aux1)
    Connect your rudder servo to the gyro socket (on the leads).
    | 3D Championship
      On the receiver it says 'Gear', so i wasn't sure if this was where the gyro gain lead went or not,Thanks Rob i'm all clear now
        Yes - you will use the Gear switch to control the Gyro Mode - Normal or Heading Hold. The Gear channel travel points will be set to determine the Gain setting on the Gyro.
        Edmund
        All Electric:
        Big Plank: Jabiru SK
          if you look in your txc handbook it should tell you look at the futaba one i think it is?
          coirrect me if i am wrong
          liam
          Taort 450 pro v2 fbl
          mz18
          proud owner of 2 egs
          sponsored by :
          KBDD International Pilot
            Futaba receivers have slightly different channel assignments - Throttle is channel 3 and Ail/Ele are promoted to 1 and 2.
            Otherwise, they're the same
            | 3D Championship
