Ar7000 flashing lights
  • Ar7000 flashing lights
    Got this AR7000 RX and after its been bound to the heli , switch off reboot after removing the bind plug system is fine with steady orange lights, unplug the battery, plug it in again and the lights flash! all the servos still work but its continious flashing!
    What does this mean please, and what can i do about it?
    Andy
    Quick Connect mate. If you don't turn off your tx too the rx will assume it has momentarily lost connection and is now warning you that you've been flying out of control for a while. Cycle your TX at the same time and the problem should go away.
    Si G
      Nice one Si,had played on mind too,now at ease
        PS - got this for real on my 450 - turned out that the belt was causing static discharge in flight. If it wasn't for this warning (forcing me to investigate and solve the problem) I might have lost the heli big style.
          Thanks Si, thats sorted that one !!
