pcm9x2 rotary things on the side
  • pcm9x2 rotary things on the side
    is it possible to turn off the flap lever on the left side of the tx, or can i have it not linked to the pitch. not had it long and still learning. all ideas gratefully received.
    Chris
    T rex 600n, OS 50, MP5, 3050's, Throttle Jockey, 9254, TT carbons, 401 gyro.
    T rex 450 v2, 65 mg's, 9650, 401, revo's, v blades
    Walkera 4#3b no numb fingers indoors.
    JR PCM 9XII.
    And 1 egs
    Yes you need to go into the first menu turn on holding down enter
    Device select -> Pitch Trim-> Inhibit
    Why this is switched on by default on a heli is beyond me
    Phil
      thanks phil, i was in that menu earlier pondering. i'll give it a go tomorrow.
      Chris
      JR PCM 9XII.
      And 1 egs
        No worries I just automatically do it when I setup a new model now. It took a few minutes to remember how to do it
        Phil
          For a helicopter pilot they seem to be the most useless and annoying thing about the 9X and most other TXs. Have you moved them and then can't work out why your settings are all to ****?
          Member of Mk Heli Club
            for scale pilots with retracts its probably good
            Matt
            Current = Blade mcpx v2 + DX6i
            Future = 1st - PL6 + PSU 2nd - Chase 360 3rd - DX9 4th - Who knows...there's too much choice
            One Eddie Gold Starsigpic
              Hows your flying coming on Chris?
              Done anymore since we saw you at the field?
                Only when i put the 2.4 module set in, had a quick fly then the module crapped out. so back on 35 meg. did get the throttle jockey sorted tho.
                Chris
                JR PCM 9XII.
                And 1 egs
                  Good one.
                  What was the prob with the Jockey?
