I picked up a pcm9x2 cheap recently and it had a LiPo as well as the standard battery but no charger, how do i go about charging it as it is a 3s orca with no balance lead only power lead. help please.
LI PO charging
Hedgehog alert.
That's the hedgehog one isnt it. Carefully. Don't forget if the capacity is less than 80% of the original you need to throw it away.Originally posted by chris99 View PostI picked up a pcm9x2 cheap recently and it had a LiPo as well as the standard battery but no charger, how do i go about charging it as it is a 3s orca with no balance lead only power lead. help please.
What voltage is it giving. If its 12.6 then its balanced. Otherwise it may or may not be. Then you pick any 3 numbers less than 4.2 and rearrange them to add up to the current voltage. Once you know that you'll know what to do.
ChrisFlasher 450 Sport. Assan GA250 with 520 tail servo, MKS DS450 cyclic.
Blade 130-X, MSR, MSRX
Phoenix Sim
