If you aren't aware the 9Z WC is being discontinued and replaced with this.
T-12 MZ 35 MHZ [ ROBF8057 ] 1,599.95EUR For a larger representation you click on the picture. With these 12 channel computer remote control is introduced consistently the outstanding PCM - 2048 G3 technology also into the upper performance class. The new PCM 2048 system offers 12 channels with a dissolution of 2048-Schritten and is over approx.. 40 % faster than the past point system PCM 1024. Quasi a real time price increase. The modulation is switchable and compatible to PCM 1024 and FM (PPM) 8 channel. Most modern technology graceful designed and ergonomically packs in a light, sturdy housing. Optically responding and ergonomically balanced. All control elements are arranged perfect and contribute to the elegant general impression. The large, reflektive LCD monitor with 300 x 128 dots is harmoniously into the noble housing integrated the switching center of the plant and. The operation of the plant been made by the 3-D-Hotkey as well as one quadruple jack (CROSS key), supports from the graphic surface. The plant is with 2 independent operating systems equipped # WindowsTM CE, for the control of the display and the operation # FUTABA operating system as the control and a check of the model functions as well as HF radiation. By a digital control stick trim retrimming or a trim value storage, redundant with model memory change, is. A position display of the trim value as bar diagram takes place in the LC display. FX 2,5MM (1) OF 1-8236 1-8236 COACH CABLES FF-9 - DIN 6POL (1) 1-F1592 1-F1592
When Ripmax get's it they'll no doubt rip us off, like the 14MZ where you don't get any servo's unlike other countries.
