Can anyone advise is it ok to use 2.4 in carbon fibre air frames mainly gliders or in glass ones that have carbon toes ? HELP
spectrum 2.4
Glass yes....Originally posted by jimmyo View PostCan anyone advise is it ok to use 2.4 in carbon fibre air frames mainly gliders or in glass ones that have carbon toes ? HELP
Carbon Fibre I wouldn't advise it
But check out some of the american solutions there using load based aerials ?
If you get an rx that accepts multiple satalite receivers then you could fit them on the outside of the aircraft perhaps?www.heli-extreme.co.uk a good club in south Sheffield
Originally posted by moyesboy View PostIf you get an rx that accepts multiple satalite receivers then you could fit them on the outside of the aircraft perhaps?
Kind of defeats the object of having a sleek smooth exterior though, even the servo arms are normally faired in
Phil
