Any ideas how you bind the spektrum rx when using the duralite system??
Spektrum Binding with Duralite System
the best way is plug your power source into any of the servo slots on your receiver (make sure you plug it in the right way + and - and signal
then connect the bind plug into the battery slot.
switch on your power supply your receiver will flash
switch on you tranny whilst holding the bind button
after a few seconds the receiver lights will go bold
you are then bound
MARK
LOGO 500 V-BAR v5.2
GAUI X4ii
PROTOS 500
MINI PROTOS 6S (stretched )
GAUI X3. 6S
JR DSX12
14SG S-BUS
proud owner of 2 x EGS
www.bmmfc.com
