Spektrum DX7 and AR7100 RX - Binding Problem
  • Spektrum DX7 and AR7100 RX - Binding Problem
    I am trying to Bind the afore mentioned equipment. I have put the bind plug into the +/- port on the RX, powered on the BEC, pressed and held the bind button on the back of the DX7 while turning on the DX7 and I am unable to get it to bind.
    The manual talks of LEDs etc flashing but I just aint seeing it. I am reading the manual from this location
    http://www.spektrumrc.com/ProdInfo/F...100-Manual.pdf
    Anybody?
    Kindest Regards,
    Toni
    aka Talisa
    Align T-Rex 600 Electric - Carbon Fibre
    Align T-Rex 600 Electric - Metal Frame (Airwolf being fitted)
    Century GL450SE x 2
    Honey Bee King II with Airwolf Fuselage
    Blade CX2 - Jet Ranger Rescue Fuselage
    Phoenix Sim V1.05.j
    Spektrum DX7 Transmitter
    Sussex Model Centre - Worthing - U.K.
    http://www.sussex-model-centre.co.uk/
    RC Lighting Specialists
    http://www.rclighting.net/
    Your bnid plug needs to be in the battery port, so either
    plug your battery / power switch in another port
    use a y-lead
    use the power switch which came with the receiver
    Power up your rx first, the leds on the recievers should flash fast
    press and hold the bind button on the back of your dx7 and power on.
    After a while the leds should stop flashing, go off and then come back on solid.
    Power off the receiver and remove the bind plug.
    power on the receiver and it should connect to the dx7 and the receiver lights should be on solid.
    Hope that helps .
    Regards,
    Jason
      I shall see if I can find said switch. Thanks J
      Toni
      aka Talisa
      Century GL450SE x 2
      Phoenix Sim V1.05.j
        That sorted it, thank you
        Toni
        aka Talisa
        Century GL450SE x 2
        Phoenix Sim V1.05.j
