Kbar
  • Kbar
    I also am here because I need help because I need help wiring my Yellow KBAR on my Align 450 L 6S Dominator. I hope SOMEONE knows which port gets the ESC wire plugged into it to power the unit. I am using the KBAR with a Spektrum sat and eliminated the AR 8000 so knowing that there are very few people who know much about this unit, I could use some help. I have 3 choices, RXC.RXB,RXA. I am currently in RXC. Could someone who knows this gyro PLEASE HELP. Also, I am new to this fourm so if I messed up..I AM SORRY.
    Blueflash1000rr
    Welcome Blue flash. as you have also included 1000RR in your user name any slight mistakes will be forgiven
      RX-B is for the esc. RX-C can be used as a second voltage input. For RX-A don't use it, if it takes power it will fry your unit. Only the upper pin can be used for RPM signal if your unit has an internal governor function. I believe the yellow Kbar's don't support internal governor. So leave it as it is.
