Vcontrol throttle wedges. How do you fit them?
  • Vcontrol throttle wedges. How do you fit them?
    Just got my wedges from Mikado, great service from them.
    How do I go about fitting them?
    Lynx Heli Team Pilot
    Anyone? Took the TX apart but can't figure it out.
      Hi take the back off the set carefully unplugging the cables as you go, at the top and bottom of the throttle stick you will see where the wedges go with the little screw threw the middle they are fiddle to get in with a pair of tweezers to get them in place and drop the screw into the hole and tighten.
      iCharger 4010 , PL8 charger,
        Sorted it in the end. Couldn't work out where they went but then after staring at it a while I realised. Ended up filing off the lumps in the wedges as it was really short to start with. Really nice now although I've got to get used to the throw. Feels better on a quick try on the sim though.
          Do not forget to calibrate your sticks after fitting them.
            Yeah did that I think. Was a bit too easy so hope I've calibrated properly
