Some of you may know that I have in other threads, been chasing a servo judder on my 800.
I have changed the servos, removed all unnessesary electronics, tested wiring for continuity. Changed sats and sat extentions from by BD3SX FBL.
The judder still happens when servos are removed from the swash linkages. THIS ONLY happens when elevator (3 servo operation) is input and is fine and smooth on aileron (2 servos).
The judder creates large power draw from the servos dropping the available voltage to my FBL....with sats plugged in.....= brownout.
WIth the FBL enabled I can lift the heli and tilt through all direction including pitch and the servo movement is fine. Until yesterday I thought I had nailed it down to the FBL unit giving a bad elevator signal. But after thinking about it, when I tilt the heli the movement is smooth where the FBL (without tx input) is running a elevator signal to counter act the tilt then it dawned that maybe it could be a poor tx signal and I'd forgotten about the Tx and I dont have a spare.
What does a bad Tx signal/pot'gimbal look like? Can I see this in the servos will it be evident maybe as a judder?
It's a DX8
Thanks in advance
It's a DX8
Thanks in advance
