Grrrrr help please
  • Grrrrr help please
    Bit off topic but not much I have a client that wants to controll 2 rx from 1 rx at the same time. Is this possible. I know that spektrum won't but I heard that you can with a futaba fhss setup. I have been adamant that it can't the whole idea of sst was to prevent this or so I thought.
    Trex 600nsp vbar
    trex 500 esp
    Logo400se R.I.P (Resting in pieces)
    hk450 4s beastx
    Lynx heli hybrid 130x
    DX8
    I think you can bind two identical DSM2/DSMX Rxs to the same model on a Tx, and effectively control both at the same time. [The Tx does read back info rfrom teh RX at bind time, but I think it's just Rx info such as DSM2/DSMX, # channels, suppoprted frame rates, etc. This would get overwritten by the 2nd bind - but by identical information.]
    In most applciations, this is unlikley to be a good idea...
    Yes, it's th@ tw@ Scallyb@...
      Thankyou. I knew someone on here would know even if it proved me wrong. just to put your mind at rest we are trying to trying to controll 2 robotic tv cameras using rc. We where thinking of using one on the left stick and one on the right. Bothe cameras would have to perform different tasks at the same time. Can anyone see any possible problems with this.
      Trex 600nsp vbar
      trex 500 esp
      hk450 4s beastx
      DX8
        no problems if you can get them both to bind... I didnt think that was possible with spektrum stuff due to the unique identifier of each receiver.......
        on 27Mhz you would have no issues.... just use two of the same crystals. Cant use 35Mhz as its airborne only, I think you would be ok with 40Mhz though....
        Logo 600 3D --- Vortex Vx1n
        JR Forza 700 --- Vortex Vx1e
        And the proud wearer of one
          Thanks jimmy we have been down the 27mhz route. Its a bit unreliable and its hard to find brand new in the box equipment
          Trex 600nsp vbar
          trex 500 esp
          hk450 4s beastx
          DX8
            Grrrrr help please
            Futaba should allow it, I'll check.
            Invertix 400
            Vortex 285
            TBS Discovery Endurance
            X4 II
            Schluter Champion Longranger
            G4 E720
            G4 E720 Big AIR edition
            Goblin Urukay super slow
            Goblin 700 KSE Slow
            Goblin 700 KSE Fast
            Srimok Faifa
            Spectra G
            Synergy 766
            http://mangled-rc.com/
              Grrrrr help please
              Yes futaba fast will allow it, I've got two g4' powered up as I type this.
              Invertix 400
              Vortex 285
              X4 II
              G4 E720
              Goblin 700 KSE Slow
              Goblin 700 KSE Fast
              Srimok Faifa
              Spectra G
              Synergy 766
                It must be possible with spektrum?
                http://www.bladehelis.com/Multimedia/Video.aspx
                  It is possible with spectrum, done it last year for our firework igniters
                    Got it thanks to all happy days and a raise. Got to love it. 2x dsm2 ar7000 with sat to 1x dx8
                    Trex 600nsp vbar
                    trex 500 esp
                    hk450 4s beastx
                    DX8
                      I must say I thought that was why the sst was developed. How ever unlikely its still posible for me to fly your bird without meaning to.
                      Trex 600nsp vbar
                      trex 500 esp
                      hk450 4s beastx
                      DX8
                        Only if they rebind their Rx to your Tx, in normal operation then you won't be able to control someone elses heli.
                          Grrrrr help please
                          The rx is matched to the tx. Unless my tx and rx have the same Id as yours they won't connect.
                          Invertix 400
                          Vortex 285
                          X4 II
                          G4 E720
                          Goblin 700 KSE Slow
                          Goblin 700 KSE Fast
                          Srimok Faifa
                          Spectra G
                          Synergy 766
                            A rx checks for the tx it is bound to. You can bind any number of rxs to one tx. One rx can only be bound to one tx. The tx sends a code word identifying itself to the rx. Might be interesting if you use a tx with telemetry with rxs that support it. The tx would get two signals back.
                            Blade 130-X, MSR, MSRX
                            Phoenix Sim
                              Thanks to everyone so far. Now I have this project on my bench and have it working sort of how I want but.
                              I have the control for the start/stop rec on ch2 working off of the left stick like this. 0stick= standby midstick= photo fullstick= rec so you can take a photo from standby or rec. the idea was now to set the IU switch to perform the same functions ie: IU1= 0-0-0-0-0. IU2= 50-50-50-50-50. IU3= 100-100-100-100-100. I can't get it to work at all. I'm hope I have missed something simple in the programming being a spektrum man myself. Dose anyone have any ideas. I'm not sure if I have explained enough so questions welcome.
                              Trex 600nsp vbar
                              trex 500 esp
                              hk450 4s beastx
                              DX8
