So just putting together my 450 dfc and been programming the ESC, did everything as per the instructions, set throttle calibration and did the usual settings (brake disabled/heli mode/etc).
However when testing it on the bench, I notice the motor will spool up smoothly all the way until the stick reaches near top stick.. then the motor will "jump" in rpm's for some reason? Its like a little kick near the transition to max throttle - its only a small jump but still its a jump and not a complete linear increase.
I will be using throttle curves on this model, my throttle curve is currently set to 0-100% for setup and I have run through calibration 3 times to make sure I didn't make a mistake.
Is this normal behaviour of Align esc's or am I missing something?
